M
mickey
Guest
MAF: What\'s missing from this picture?
That's Aaron's MAF sensor. (The former Sprocketsmobile.)
Error code: "MAF sensor implausible result", or something like that.
Isn't there supposed to be a resistor of some kind between those two copper terminals? If you look closely you can see there is a sort of diagram molded into the plastic, showing what appears to be a resistor between the two terminals.
The symptoms match a "limp home mode", and this is the first time I've seen an ECU say, straight up, that the MAF is faulty. Seems pretty cut and dried.
If there is a resistor missing, what value is it supposed to be? A 50 cent Radio Shack resistor would be much better than buying a $200 MAF sensor.
-mickey
p.s. I'm also a little curious about where the resistor went. Kind of scary!
-mickey
